Power Antenna when cranking engine
Hello,
I have a 1995 C180 with a Fusion Aftermarket head unit. I have just replaced the antenna with a powered one from Germany but not OEM. All works well, but while I crank the engine and the antenna has already extended, the radio goes off for a few seconds causing the antenna to retrect and then extend again. I am suspecting battery condition?
