Springs don'thave to be replaced unless you actually see some defect. But you should check the spring perches for rust. They have a history of failing in the late 90s C class.
Hello everyone, my '99 C230k has 175,000 miles on it now. I've changed out all shocks, LCA bushings, balljoints, steering rack, steering ball joints so far over the last 10,000 miles. Overall the suspension is pretty good.
Next I would like to replace the Upper control arms (an easy job), the all the little rear control arms (slightly more difficult) but my question is about the springs. I'm really not looking forward to doing them because I have to take the shocks out again. I was wondering if springs need replacing at this mileage? I rarely hear about them going bad or as maintenance item. It's usually the bushings, joints etc that wear at around this time. The ride does feel slightly cushier than new, but that might because of the old upper control arms/rear control arms.
Please let me know, I appreciate it!
1999 C230K Sport
Upsolute Chip
BMC Airfilter
