Yes its my favourite colour c36 im tempted to buy myself
, bit rough around the outside but as you say all problems are sorted just refresh the paint and you'd have a nice amg 202 for much less than the other options!.
Haha I actually threw the gearbox in the bin earlier this year doh, your better off with the 6 speed I think though I have a hunch you need the touchshifts tunnel add on for extra clearance around the shifter area. I still kept a few bits like the pedal box etc thought maybe one day I would do a manual c43 and recently came close to purchasing a 711.670 box but realized just how tricky this would be if done properly with correctly rated parts and threw it in. the C36 is a much better manual project.
Krum,
Sounds good, higher rpm is always more exciting to drive
. If your turbine is common/cheap with optional housings you could try increase turbine housing size/AR this may help your breathing up high and might not effect your low end as much.
