Results 1 to 9 of 9
Thread: Can i use my stock lug bolts on amg monoblocks
Hybrid View
    Member
    Jan 2015
    new york, New York
    51
    Question Can i use my stock lug bolts on amg monoblocks
    Ive been looking to order a new set of lugs because I've been told that I can't use the stock 15s on monoblock II but I've also seen some have used their stock lugs on 17 monos. So I've gone out to measure the thread lengths when my stock bolts are in the rim. I have a pair of 17s and 18s and the both measure about the same, as well as my stock 15 alloys. Can someone tell me if I can use my stock lugs or no?? The first pic is of the stock 15s, the second is the 18" and the third is the 17". also the size of the entire nut and shank length Click image for larger version.
ID:	2449Click image for larger version.
ID:	2450Click image for larger version.
ID:	2451Click image for larger version.
ID:	2452Click image for larger version.
    Aug 2012
    SoCalif
    1,011
    They all pretty much stick out the same distance off the back as the OEM 15's- I do not see why not.
    Fremont, CA
    1,900
    it looks like you're ok... not unless you're gonna space them out..
    Member
    Jan 2015
    new york, New York
    51
    the only thing is the stock lug go far into the rim to the point you cant see them unless your eyes re level with it
    Member
    Mar 2015
    Fairfax, VA
    61
    Can anyone lead me in the right direction of correct OEM wheel locks that go with our stock lug bolts?
    Member
    Jan 2015
    new york, New York
    51
    you want the part number? i have a set in my trunk
    Member
    Mar 2015
    Fairfax, VA
    61
    Yes please!
    Member
    Jan 2015
    new york, New York
    51
    Does this answer your question? Click image for larger version.
    Member
    Mar 2015
    Fairfax, VA
    61
    That helps a lot, thanks!
    Just wanted to make sure, which model do you have?
