Results 1 to 14 of 14
Thread: DYI camber arms
    Jan 2003
    207
    DYI camber arms
    Spent 3 hours last night replacing my stock dogbone w/ Jeffs arms. Youll need 18mm & 17mm hardware, some nick nacks like a flathead, crescent wrench maybe & beer. Here are some pics...
    This gives you an idea of the size of the arms. Imo the fluid in the green bottle between the 2 arms is the most important tool youll need for the job...
    http://www.imagestation.com/picture/...3/fa960a23.jpg
    1st step, spray wd-40 on the bolts & get the inboard 18mm stuff loose. I was able to do it w/ 3/4" closed end wrench w/minimal persuasion. I had to use a socket or another open end 18mm/3/4" wrench to hold the bolt while I unthreaded the nut.
    http://www.imagestation.com/picture/...c/fa960a14.jpg
    2nd step, get the 17mm stuff loose on the hub side. This was easier than the inboard side by far. Tap the hub bolt out(it might push out). After this you can work the arm around so the inboard bolt will just push out with your finger.
    http://www.imagestation.com/picture/...d/fa960a0d.jpg
    You'll have to pull the hub assembly towards yourself to get the inboard side to yank the dogbone out. You'll figure it out.
    http://www.imagestation.com/picture/...f/fa9609fb.jpg
    3rd step, install the new arm. This photo shows how you should 'build' the arm on the hub side. I used a thin coat of bearing grease on the spacers & stuff. It serves a dual purpose of keeping them from falling out while you position the arm & lubing moving parts... http://www.imagestation.com/picture/...0/fa9609e9.jpg
    Here is how the hub side will look. 3 washers is a perfect fit. 1mm sperates the end of the bolt(threaded end) and the A-arm. Its a close fit but its cool...
    http://www.imagestation.com/picture/...9/fa960a1b.jpg
    Tighten up the inboard side & use your best judgement is 'eyeballing' your camber. Snug up the jam nuts and put your wheels back on & go get an alignment! http://www.imagestation.com/picture/...f/fa9609e4.jpg
    Back view of my rear suspension...
    http://www.imagestation.com/picture/...e/fa960a12.jpg
    I would not pay anyone to do this install. I hear people are being quoted 3 hours labor to put these in. Yhea it took me 3 hours but I saved $250 bucks. I started at 9pm & was done by midnight. All I could think to myself while doing this swap was Damn, I'm the only dude in the USA tonight improving the suspension on a handbuilt, AMG car! HeHe.
    3.6,
    Nice job on the write up. How is the ride with the new arms?
    It looks like everything fit up correctly.
    Thanks for the info 3P6,
    Are those new bolts you used for the install? If so do you know the size I should buy before I start? Also are those Stainless washers?
    WTS
    1999 C43
    Jan 2003
    207
    Speedy,
    I can tell the ride is different, more movement in back, but only slightly & I'm not aligned yet so we will see next week how it feels. I think my toe is off also right now because of the arms.
    toemend,
    Those are the stock bolts I re-used and washers are plain jain stamped steel. Nothing wrong with using that stuff though.
    nicejob mang!! tell us how they are feeling in like a week or something
    Great job!!! I cant wait til I get to do this! I am waiting for some bushings!
    The new arms allow the rear suspension to move more freely because of the new bearings, where the stock camber arms rely on rotating the stock rubber bushings.
    I also noticed that the car seems to corner with a little more locked in feeling, as the camber is fixed now.
    Sep 2003
    176
    All of your hardware is metric right? I just don't have many standard tools. I havent bought a standard tool in five years.
    They look pretty sharp (nice).
    The Camber Arms use your stock bolts and nuts. So yes all the hardware is metric. You need 18mm wrench and 19mm wrench and depending on which bolt MB used on the hub side maybe a 12mm, 12 point socket.
    Feb 2004
    3
    what happened tp the pics
    Oct 2003
    478
    its not letting me see the f@#*ing pics.
    There is a typical problem with imagestation and pic hosting. I would suggest emailing 3.6 to ask he has pics saved elsewhere, or ask him to post pics on another hosting site and update his DIY.
    2,283
    If the pics aren't working when you click the link, right-click the URL and copy the shortcut. Paste this link to a browser window and the pic should work
    Oct 2003
    478
    swwweeet, the pics work. thanks good job
