Thanks! Actually putting my stock camber arms back in to remove a lot of camber, need to put the power down!
Update #5
Well we ran into problems as always with working on cars, When removing the exhaust one of the bolts stripped and with almost no room to work with I spent a day drilling out the bolt head to remove the exhaust....
After that I proceeded to drain the trans and remove all hardlines, harness, and everything else needed to pull the engine and man was it FILTHY under the car
