Results 1 to 21 of 21
Thread: Dom's C43 build thread (55 Swap)
    Dec 2015
    14
    Hey guys figured i'd make a post showing the recent changes to my C43 before she goes back under the knife. Changed up the wrap got bored of the silver glitter very quickly, added shorter camber arms, removed front bumper grill and supports, added rear roof spoiler and a few other goodies here and there. She just hit 230K miles and is now under the knife for an E55 engine swap :v:
    Wrap - Oracal Turqouise/Lavender by MacWraps
    Wheels - Brabus IV 18x9.5 +20 18x10.5 -10
    Dec 2015
    14
    Camber has been removed, Changed tires to 235/35/18 265/35/18 and am planning on flaring fenders to run wider tires, Rebuild on the E55 engine has begun Cant wait for this swap to be complete.
    Replacing -
    Valve cover gaskets
    Oil & Filter
    Coolant
    Water pump
    Rear main seal
    Spark plugs
    oil pan gasket
    Engine had about 100k on it when it was pulled from a salvaged E55
    Moderator hvmercy's Avatar
    Dec 2003
    2,092
    I suggest you replace the CPS. At 100k miles this is bound to go bad anytime. Plus it's most convenient since the engine is out.
    Dec 2015
    14
    Quote Originally Posted by hvmercy View Post
    Thanks for the tip! will do
    Dec 2015
    14
    Dec 2015
    14
    UPDATE!!
    Spent a few hours after work last night putting back on valve covers with new seals/gaskets
    also installed
    -New sparkplugs
    -new oil filter
    -new thermostat
    Some picutres of the engine with valve covers removed
    Putting in a little work!
    Starting to look all cleaned up!
    Dec 2015
    14
    UPDATE!!
    also installed
    -New sparkplugs
    -new oil filter
    -new thermostat
    Dec 2003
    2,092
    Welcome to club202 by the way.
    I'm trying to orient myself as to where the CPS is located. I'm just going by memory.
    From your pictures it isn't that obvious so I'm guessing the cps is located in the bell housing where the engine and transmission meet. Keep us posted on your project.
    Quote Originally Posted by AMG_Dom View Post
    Dec 2015
    14
    Thanks! my friend helping me has a lot of knowledge about working on Mercs so ill just ask him, thanks for trying to point out the location though!
    UPDATE #3
    Got around to just about finishing up the rebuild last night.
    Started out swapping the water pump
    Fresh water pump, thermostat and tensioner pulley
    The got into replacing the rear main seal, actually an easy task with the engine removed from vehicle
    Dec 2003
    2,092
    Welcome.
    There it is, 10 o'clock
    Dec 2003
    2,092
    Welcome.
    Dec 2015
    14
    UPDATE #4
    Was sadly not able to spend as much time on the car this weekend as I'd hoped but I am waiting for a few necessary parts to arrive tomorrow at the dealer. Should have the engine pulled tonight or tomorrow and have everything hooked up by the end of next weekend...
    My buddy, and previous owner of the car, David (SD202) stopped by to lend a hand
    And then work commenced, will take more pictures of current progress tonight.
    Dec 2015
    14
    UPDATE #4
    Senior Member nelius's Avatar
    the 425, WA
    319
    love those wheels! Good to know we can fit such wide wheels. You got more camber than the average 202 but still, looks sharp.
    Dec 2015
    14
    Quote Originally Posted by nelius View Post
    Thanks! Actually putting my stock camber arms back in to remove a lot of camber, need to put the power down!
    Update #5
    Well we ran into problems as always with working on cars, When removing the exhaust one of the bolts stripped and with almost no room to work with I spent a day drilling out the bolt head to remove the exhaust....
    After that I proceeded to drain the trans and remove all hardlines, harness, and everything else needed to pull the engine and man was it FILTHY under the car
    Dec 2015
    14
    Update #6
    Finally it was time to pull the old engine!
    After it was out I had to disconnect the transmission and swap over some other bits and pieces to the new engine
    And then the moment I've been waiting for, time to drop in the 55!
    Hooking everything back up! almost completed it yesterday but she WILL be running tonight
    Dec 2015
    14
    UPDATE #7
    Sorry it took so long for the next update been having too much fun driving this beast around town! The difference is amazing, the car floats along effortlessly almost hard to keep her under 80 on the freeway. Would recommend this swap to anyone thinking about it. Having owned a W210 E55 previously and now this, its definitely much quicker off the line going to get wider tires today as without traction control off it wants to spin them up to 40+ mph
    Went to Targa Trophy at HRE Wheels HQ last weekend had a blast driving around with some great friends taking pictures, waiting on professional shots but heres a few to hold you over
    Short crappy video of the car after the swap!
    https://youtu.be/Dtxjb7646X0?t=2s
    May 2013
    Durban South Africa
    264
    Congrats on completing the swap. Is that Plastidip on the car?
    4,533
    Nice build. Saw this on IG and was curious if you were on the site.
    Hope to do the same. Been saying it for years. Lol
    Junior Member BlownC43's Avatar
    Dec 2013
    Palmdale, CA
    16
    very nice, where in Cali?
    The wrap makes it really cool. I dig it!
