Results 1 to 6 of 6
Thread: 722.6 upgrades?
    Feb 2013
    biglerville pa
    783
    722.6 upgrades?
    Was looking and I found these guys work on the Dodge variant of the 722.6
    Opinions? Any possible in site on them ?
    My car shifts waaayyyy too slow for my taste
    http://www.hotrod.com/how-to/transmi...ssion-upgrade/
    Dec 2014
    London, UK
    15
    You could fit an Ole controller, but you'd need a stand alone ecu for the engine with that. The ole controller lets you adjust line pressure which is what affects shift firmness.
    Or you could fit a 722.6 from the V8 or v12 AMG, you would just have to swap the bell housing if you have an inline engine in your W202, otherwise your stock bell housing will be fine. The AMG V8 & 12 722.6's have loads more clutch plates so they are much stronger but actually I'm not sure if the shift firmness would change as you would have the same line pressure..
    Feb 2013
    biglerville pa
    783
    I wouldn't doubt that the s class cars ecu is set to shift harder
    Junior Member BlownC43's Avatar
    Dec 2013
    Palmdale, CA
    16
    I upgraded my w202 722.6 to the 722.643 due to the hp increase
    Any write up about the swap you did?
    In Charge
    Left Lane
    4,533
    722.6 has limits of close to 700hp/tq, your stock tranny could easily withstand the extra power from the HPS system. Which car uses the 722.643?
    1998 C43
    1994 C280 (Retired)
