Results 1 to 5 of 5
Thread: New wheels 17"
    Aug 2017
    15
    New wheels 17"
    https://www.aspiremotoring.com/produ...yABEgL3uPD_BwE
    So basically my 99 C43 has some cheap knock off monos. They are 17". Can't read the casting on the inside to see offset.
    New wheels are 17x8.5 et20 for front and 17x9.5 et30 rear. Just curious how much gap there will be at fender.
    I can't find anywhere posted of this size and offset anybody is running.
    I'm sure I just opened myself up to being blasted on here. That's ok. I am willing to take any comments bad or good.
    Thanks guys.
    Aug 2017
    15
    Tires play a roll I'm sure. Just wanted to know. I really don't want to wear spacers.
    If you have a manual, then you could get the factory specs (I dont know them off hand, though I should). Once you have that, use the calculator tool at the top of this section and plug in the OEM then aftermarket wheels. It will tell you how much of a difference between the two and whether or not it will stick out further or inward.
    Aug 2017
    15
    Perfect. Thanks!
    30mm to 37mm offset should not give you any problem when fitting 17x8.5 wheels.
