Results 1 to 2 of 2
Thread: Shock recommendations for B&G springs?
    Dec 2017
    14
    Hello, I'm trying to get as low as possible without coilovers. From what I've gathered, the B&G springs drop 1.6", and the H&R drop 1.4"/1.3". I assume I will need to get #1 pads all around to get even lower. With that said, I decided to go with the B&G, but I'm not sure which shocks to get. I saw a few from koni, ky, bilstien, some with external adjustments, and some without. Does B&G springs work better with one of these specific shocks, or does it matter? Any recommendations? Thanks in advance
    Can't go wrong Bilstien. This shock is not too stiff.
