map sensor data output?
I'm looking at getting a digital boost gauge for my 99 kompressor. The kit comes with it's own 3 pin map sensor, but I want to see if I can just tap into the stock 3 pin sensor instead of running 2 map sensors(seems redundant).
The company that makes the gauge asked me for the data output(Voltage against pressure) of my stock map sensor to see if it can indeed be wired in to avoid running 2 map sensors.
With that said, does anyone know the data output of the stock map sensor?
Thanks in advance.
