not if you have a bad O2 sensor! LOL i would change the cheaper one first which is the 02 sensor, BUT if you have a freind with a good MAS in his w202 then swap him and see what happens.Originally posted by ryhi
ok i got them pulled today and the mechanic said there were 2 things wrong...the first code was the 02 sensor, and the second one was the MAF sensor. he said the MAF sensor might be sending the 02 sensor a bad signal, therefore triggering the 02 sensor code. if i replace the MAF sensor will the 02 sensor be fixed?
