P0460 — FLI Fuel level sensor circuit malfunction ---probable causes: Open/short circuit, cluster, tank unit, open case GND
P0460 Fuel Level Unit ___No Change Over Miles No movement of fuel level sender detected.
P0170
Fuel Trim,Bank1 Malfunction
so if you say your guage gives you different readings from time to time
from this info i'm thinking it has to do something with your tank fuel sensor, those do go bad from time to time and mostlikely triggering those 2 codes for the same thing
