Results 1 to 6 of 6
Thread: Changing spark plugs ???
    Dec 2003
    587
    Hello I opened up the compartment where the spark plugs are and I know how to remove the three standard ones, what about the spark plugs with a box type thing I dont just want to pull it out and break something could some one advise me how I get at those spark plugs
    Why do the germans have to make everthing so difficult?
    Re: Changing spark plugs ???
    That box is the ignition coil
    you need to unplug that to have access to the plug..
    dude.... quit complaining LOL
    Mercedes M104 engine I-6 only has 3 coil pack, which is okay compare to BMW I-6 engine, which has one individual coil on top of each spark-plug (6 coil) which make spark-plugs changing job more time consuming..
    Dec 2003
    587
    yep I figured it out what size spark plug socket do I need ?
    Dec 2003
    587
    my dad is all freaking out that there not listed in the car manual so i should not put them in the look identical
    they are Bosch Platinum 4
    18-3751-4
    4418
    Can anyone confirm that there the right ones
    Dec 2003
    587
    Best ammount of money I could have ever spent its like a new car
    easy to install for a gear head my dad helped and it was easy.
    Unplug the coilpack and just pull up on it. THe spark plug is underneath. I believe the spark plug socket size is 5/8".
    Good luck
    Martin
