Results 1 to 3 of 3
Thread: Camber adjustment bolt part#
    Jan 2003
    207
    A 202 330 01 18
    This was installed on my C36 FRONT lower A-arm bushing. You'll need (2) It gave me +.5 deg correction. I have H&R sport cut 1/2 coil on #3 pad. I was @ - 2.2 & now I am @ - 1.7. Not much but better than nothing. Some shops don't know about this part so let 'em know! You can also use (2) on the REAR lower bushing for more adjustability for castor & possibly a little more + correction for camber. The rear on 202's has NO camber adjustment from the factory (K-mac Australia has the solution)
    Moderator hvmercy's Avatar
    Dec 2003
    2,092
    Thanks for the tip.
    In the meantime while I'm waiting for Speedybenz's reply I'll
    try to get this part.
    Re: Camber adjustment bolt part#
    Correction, speedybenz has the solution
