Srs
Hi Everyone, I am new to this forum and I could not find a thread with this problem. I Have a C280 Sport and for the longest time SRS light seems to have a mind of its own. The SRS Light turn on and off any time it wants. The computer does not seem to find any errors. We have reset the computer and the light still have a mind of its own.
Any Hints,
Have you tried checking under the passenger seat to make sure the sensor is plugged in and tight?
What should I be looking for..
Any disconnected plugs or loose ones.
Thanks!!! ...
I disconected and conected everything under the seat and the problem was fix..
Thanks...
Be careful when disconecting plugs under the seat. It can trigger a seatbelt buckle malfunction. It happened to me.
just out of curiosity how did you fix the seat belt malfunction, did you get any lights on the dash to turn on?because my srs light and airbag light are on, the srs light goes on and off too.
The seat belt never malfunction, only the SRS lights where on.
The SRS light came on and remained on for 2 minutes after starting the engine. It was cleared (RESET) by the dealer.
