You could take apart your OEM 202 mirror and use that wire harness on your 210 mirror and then it would be plug and play. Or purchase the 210 pins/connectors on the door side and convert you cars connector to 210 style.
I remember your post however on bnzsport and you bought memory mirrors. You will not be able to use option 1 above as the connection on the motor itself is different than non memory mirrors.
I will see about the 210 partnumbers later tonight.
