Results 1 to 7 of 7
Thread: 210 center console cover on a 202
    I havent measured but if someone has access to both a 210 and a 202 you wanna see if the center console cover fits? Doesnt have to just bolt right in but how about it almost fits and just some light modifications are needed to make it work.
    Im thinking since the 210 comes with the double din opening this might make a comand install in a 202 look alot nicer.
    259
    We didn't think about that huh?? But wouldn't the lay out of the W210 buttons and din sweeps be different than the W202? I know that the 202 has a crease, where as the W210 doesn't...
    I will check. Going to Pleasanton during lunch today, to the dealer,!
    Token Chrysler owner
    Joey I might be able to do that
    I'll let you know
    But last time I remember they are definitely taller than W202's..
    But I'll measure it this time..
    J Irwan
    Can ya check if they got my parts today also?
    259
    should I pick them up if I they got em>?
    wrong...someone thought of that...
    The topside of the panel is too small (top switch row)...the bottompart is too wide (but that can be shaved off)...the space between the bottomside of the topswitches and the topside of the climate control is too long/big/much...
    it doesn't fit
    greetingz,
    d'oh
