Hey Speedy Benz, Did you ever get the rear dif issue worked out ?Originally posted by speedybenz
IS there a way to tell what rear diff's have a 3.46:1 rear gear ratio and if the differential housing will bolt up to a C43 subframe?
Or can you buy the ring and pinion gear and just install the new gears into the existing diff?
Any chance this info is out there on some parts CD?
MB Autowerke has a set up they sell for about $1,500 plus core. They use it on their C55 Kleemann..
