Results 1 to 8 of 8
Thread: can 95 C36 be used with OTTOSCAN
    Feb 2004
    167
    it seems an excellent idea to have a palm and able to read all that info including Engine light codes but its supposedly only for 96 and up cars. i heard mbs in 95 were already OBD2. can u confirm this. will OTTOSCAN work?
    as far as I know, 95 cars have a fully functioning obd II system... 94 cars also have obd II, but it is not a fully compliant version....
    95 M3 (US)
    87 190E 2.6
    95 318is (EURO)
    1,169
    it should work
    Sep 2003
    134
    My 95 C220 is OBD II compliant. Any OBD II scanner should work.
    There is a way to get a ton of codes via the AC unit by holding in some buttons.. it tells all sorts of stuff.. air temp at motor etc..
    1996 C 36 AMG
    Feb 2004
    167
    awsome. that what i would like. my e36 had something similar.
    what is the procedure to retrieve those hidden settings?
    Oct 2003
    454
    I think you can get the Otto Scan with a 38 pin diagnostic connector (X11/4). This allows you to see much more that OBD II codes. Like O2 sensor voltages, short term trim and more. Here is a good link on what scanning that port Vs. the OBD II port can do for you. X11
    moebiusgold
    \'95 C36
