Good Idea thanksOriginally posted by JRE320
Why don't you try taking them off and compare the part numbers.. That's how I found out that my air mas for my C280 and E320 are the same.
Why don't you try taking them off and compare the part numbers.. That's how I found out that my air mas for my C280 and E320 are the same.Originally posted by BenzMeister
So a 99 AMG MAS should fit my 99 C280, thanks.
E55 2000
M-3 2014
Benzmeister
1999 C280
In the picture of the MAS sensors above the difference is not C36 versus standard M104. The sensor on the left is for an ODBII car 96-00 W202 and the sensor on the right is for a non ODBII car 94-95 W202. My 95 C36 has the sensor on the right.
Oh and we should note that 9 times out of 10 the MAS is being fouled by an over oiled K&N air filter. (raises hand) I am looking into other performance filters currently (ITG, etc) and let you know what I find.
~dnm
1995 C36 AMG
Yes, people have a tendency too over oil K&N, I've used them in all my cars for a decade and never have a problem. Trick is, after you clean the filter, just put a few drops of oil between the seams and let the filter stand for 15 to 20 for the oil to absorb. even then I take a towel and gently wipe the filter down for any excess oil. Never had one fail yet. One other thing, unless you live in the sand there is not need to clean them more then once a yearOriginally posted by kodiak
~dnm
Benzmeister
1999 C280
For those that have an ODBII car, codes P0171 and P0173 are a tell tale sign that your MAS is failing. When the check engine light goes on, just have the codes read to be sure.
I just went through this last week, but fortunatly, my car is still under warranty.
19000 miles!
Completely stock, no K&N.
-B-
The picture of J Irwin's MAS sensor, side view shows there is a peice missing. There should be plastic cover on the bottom that would enclose the side of the MAS sensor to direct the air up into the metal strip.
Also to clean mine I remove the sensor and spray it with Carb Cleaner, like 1/2 a can or more and then spray it with Brake Cleaner, again 1/2 can or so to remove the carb cleaner residue.
Jeff
