Results 1 to 15 of 15
Thread: Routing Cables
    Mar 2004
    13
    Routing Cables
    hi, im going to be fitting a sub box and amp to the merc in the next few days and wondered where most people route the cables?
    Normally run them down the sides but just wondered what you lot do?
    1,669
    run them down the sides...they tuck right under the door sills. its pretty hard getting all the wires through the seat to the trunk though.
    Mar 2004
    13
    Do i want to take the Sill covers off? they are on clips from what i gather any way they come off or just give em a tug?.
    Oct 2003
    478
    make sure you run all the rca's through the passener side, because the battery cable is on the drives side and if run them on that side you'll get unwanted engine and back ground noise. goos luck and let us know how it turns out with pics if possible. :bunny:
    Mar 2004
    13
    yep will do cheers for the help.
    Oct 2003
    478
    oh yeah you do want to take the sills off, also when running the wires becarful w/ the yellow tubes. the back seat needs to come off as well.
    Mar 2004
    13
    yeah i want to route the cables well out of the way so im guessing that i need to take the sill covers off and put the wires either under the carpet or is a channel for them to go in?
    Do the covers just prize off?
    Moderator hvmercy's Avatar
    Dec 2003
    2,092
    huh?
    do you mean "pry off"?
    Just pry off the door sills, they have 3 clips for the front door sills and 2 clips for the rear door sills.
    Also, The back seat is really easy to take off. You pop the bottom piece by pushing the switch(underneath the seat, 1 on each side).
    The upper piece is held by 3 screws at the bottom of it. Locate them and loosen the screws. Once it's done, push the piece UP and then pull.
    Mar 2004
    13
    cheers and yeah pry
    Mar 2004
    13
    just wondered what the blue and white wire is on the mercedes loom?
    anyone know?
    either remote amp or antenna turn on/off
    Mar 2004
    13
    yeah, i think its just a dummy wire as the arial seems to be a static one, unless its broke? are they normally fitted to a 97 C200 esprit?
    Mar 2004
    13
    there you have it all in and sounding pretty good.
    Cheers for your help.
    wow good job! Nice wheels too!
