Results 1 to 13 of 13
Thread: Thoughts on wheel spacers???
    Question Thoughts on wheel spacers??? Luwin...help!!
    Just wondering what u guys think to wheel spacers?? anyone with experiences using them??
    I want to put a set on my rear wheels, just to fill up the fender more.
    has anyone experienced problems witht hem?? what do they come with..longer wheel bolts?
    I need spacers badly also, but many have said negative things about 'em. Ask Luwin, he seems to have some experience with them. Keep me updated on this please.
    I have wheel spacers on my W202 that were machined by The Wheel Supply. They are hubcentric and I have had no problem with them.
    They are 7mm thick
    699
    I have custom-machined hubcentric spacers on the rear wheels, and I have had no problem with them. You don't want to overdo it and run a huge spacer, as that puts a lot of load on your lugs, but I haven't heard of any problems with using proper hubcentric spacers. I'm running a 15mm in the rear. And of course, you have to get longer lugs sized appropriately. Remember - the important thing to remember here is use a proper spacer - hubcentric!
    SpeedyBenz, Luwin, do you have contacts at Wheel Supply?
    My major issue is the offsets. On the rear, the lug bolts hit my emergency break springs, hence the clicking noise when the wheel turned. These are already the shortest bolts I could find so far. I could cut the bolts a dart or two, however, I decided to bent the backplate hold down springs outward. The result is surprisingly good.
    However, I am replacing my emergency brake shoes soon, I figure instead of bending the new springs, perhaps spacers are in order!
    Please post your contact at Wheel Supply, I ll give them a ring asap!
    Thanks in advance!
    Im running H&R 10mm in the rear.
    Call Sander at The Wheel Suppy. He should be able to get you what you need
    Could you tell me what area code at least, so I could look up the numbers. I live in Denver CO..and I have no ideas what's The Wheel Supply. Thanks in advance
    606
    http://www.thewheelsupply.com
    That should help ya out.
    699
    Call Sander at 909-486-1311 - tell him Luwin sent ya.
    I have 15mm spacers all around on my 300SL24 (in order to use the same wheels as on my C250D)...no problems...not even at 240-250km/h...
    greetingz,
    willpower
    Luwin and Jeff: why'd u guys use custom-machined spacers rather than H&R ones?
    CKlasse: I had the same problem with my E-brake... I just shaved my lugbolts down... but I like your solution too!
    699
    Some wheels have different center bores, so I had to go custom. Also, I'm not sure if H&R makes a 15mm. And one more thing - "custom" sounds much cooler.
