i would do a stall break start, and turn off any type of traction control, i was wondering my self if you pull the fuse will the car still work ? even when you turn it off on the dash it still kicks in sometimes, i would just let the auto shift its self and make shure you nail the kickdown switch press on the pedal hard and then harder on the take off. Run premium 94 octane and lower tire pressure in the rear take out any weight like the spare tire ect. oh biggy turn the a/c off and crack the window if you want try it with and then with out and watch your time drop.
