Results 1 to 3 of 3
Thread: what's the part number for the left xenon headlight lens on a '99 C43?
    Oct 2003
    161
    what's the part number for the left xenon headlight lens on a '99 C43? (and also the rubber gasket, if that's a separate part#)
    (left = pasenger side)
    The reason I want to replace it is because the lens is somewhat
    foggy(when compared to the right side). I did take out the
    lens and cleaned the inside, but that did not help.
    Should I also replace the right side lens? (since the new left
    lens will probably make the old right lens look foggy afterwards)
    (if so, I'd also appreciate the part# for the right side)
    THANKS!!!
    In Charge martattack's Avatar
    Jan 2004
    Kirkland, WA
    816
    The part numbers are here:
    Left Xenon Lens: 202 820 57 66
    Left Lens Seal: 202 826 13 80
    Right Xenon Lens: 202 820 58 66
    Right Lens Seal: 202 826 14 80
    It would probably be a good idea to change both since once you replace the foggy side, the side you didn't replace will probably look foggy compared to the brand new one. Good luck.
    Martin
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    Oct 2003
    161
    Martin
    THANKS!!! (again!)
