A friend of me with his C36 has that error message, after deleting the car-cache, the error message will not come back. Try that at first and check the cache again after 2 weeks
I had autozone pull the code from the check engine light.
Their scanner said
"incorrect air injection flow"
P0411
Any ideas? I am going to have my friend with a mercedes scanner check it on friday.
The smog pump rubber hose that attaches to the metal hose, and up between two of the cylinders on the Exhaust manafold popped off.
I put it back on and disconnected the battery. So far the check engine light has not come back on.
Why disconnect the battery? It is enough to clear the cache, every MB dealer can do that - without costs when you are friendly
A majority of MB dealers in the states will charge an arm and a leg for most things. There not as friendly here.Originally posted by spookie
my nearest dealer is 165 miles away.
Oh ok, I don´t know this before.
165miles? Thats really hard, we had a very good network of dealers in Germany
yeah, well there are like 3 ford dealers within 20 miles here in the USA!
Sorry for my nescience.
Ok, then "kill" your batterie for at least 5 Minutes
