Results 1 to 25 of 31
Thread: European style door lock pins
    For W202 owners, the european comes with a smaller door lock pins
    Here is the part number
    A 123 766 00 22
    They are about $1-$2 each.
    any pic..
    J Irwan
    I think I got those pins. Is it the one from the CLK?
    pic... Jun, can you take yours?
    but I have 1 style picture to show why european door lock pins are better:
    When locked, nothing is sticking out.
    click the link
    As found on your NA Spec w208 as well. So a trip to your local dealer is all that is needed for these.
    Yup! that's the one I got. I've checked the PN and it matches with the W208 door lock knob. I'll take pic in a while.
    Here's some pic of what we talking about here...
    I think it got some kind of adhessive to lock itself when you install this door knob. Plug in and twist it once.
    Unlocked....
    Locked......
    Do these work on the W203 as well?
    2006 xB - bubble tea mobile
    1984 AE86 SR5 - project levin
    Yes. This will work on W203
    Talking
    Woohoo!! Another "mod" which I already have!
    1996 C280 - African Member #1
    713
    I went out this weekend and got thes door pins. They don't go down when I lock the door
    Autostart Autostarter
    Progress Rear Sway Bar
    USDM Bodykit
    USDM Foglights
    1997 AMG C36 (RIP Thank God)
    OEM Bosche Clear Corners
    OEM AdvanteGarde Grill
    Bilstein Sport Shocks
    Eibach Springs
    Zender rear lip spoiler
    W210 mirrors
    You have to twist to break a seal inside. So do the twist!
    713
    I twisted it but it won't go in. I even used pliers. Thinging about removing the door to put them on now
    USDM Bodykit
    USDM Foglights
    Eibach Springs
    W210 mirrors
    when its closed is it somewhat down? Or you mean when you lock the door its still sticking up and hasnt moved at all?
    713
    it sticks up and doesn't move at all.
    I think the hole is too small for this style of door pin to fit in.
    USDM Bodykit
    USDM Foglights
    Eibach Springs
    W210 mirrors
    When you screw it in can you pull it off? I have these on my car and they work normally. It goes up and goes down.
    Did your locks function prior to this?
    713
    when I screw it in..no i can't pull it off but it won't go down either.
    yes my door locks work.
    i think the hole is too small for some reason to fit the euro style pins.
    USDM Bodykit
    USDM Foglights
    Eibach Springs
    W210 mirrors
    Thats funky.
    that's weird,
    the euro style pin should be smaller (if not the same) in diameter that the your OEM one..
    btw this so called euro door lock pin actually standard on the older mercedes
    E class pre W124
    J Irwan
    713
    I'm not saying the pin isn;t fitting.i'm sure it fits..it's just the hole on the door that's a bit to small I think.
    USDM Bodykit
    USDM Foglights
    Eibach Springs
    W210 mirrors
    You talking about the rubber around the hole that makes it look small?
    Rocky,
    make sure you screw it on correctly. means the pins held into the rod.....
    713
    Yep
    USDM Bodykit
    USDM Foglights
    Eibach Springs
    W210 mirrors
