Results 1 to 5 of 5
Thread: I broke cigarrette jack and glove box light..
    Aug 2004
    111
    I happen to drop a piece of bread in the car and this piece got dropped into the little hole where the actual cigarrette lighter is sticked into....
    I tried to get this piece of bread out using my GERBER (utility tool) and I got the piece out of there alright....but I happened to touch the inner part of that hole with my GERBER....
    As I have done that....two things happened at the same time...
    1. A spark was observed at the place where my tool(GERBER) touched the inner part of the cigarrette lighter hole.
    2. At that time, the glove box was kept opened and the glove box light went out
    And after that.....
    the cigarrette light won't light.....I put in other devices that hooks into that hole(such as cell phone charger....) and it does not work....
    OK.....
    First of all...
    What did I break??????
    I am going to try new light bulb for glove box tomorrow....but for the cigarrette lighter......will I have to get the new ashtray assembly????
    and also......is it possible that I messed up the fuse that might be related to this assembly????
    HELP!!!
    In Charge martattack's Avatar
    Jan 2004
    Kirkland, WA
    816
    I'm going to give you good news. I'm 99.9% sure all you did was blow the fuse on the circuit. Check the fusebox for the appropriate fuse and replace it!
    Martin
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    Aug 2004
    111
    Thanks....
    I will call dealer and ask which fuse it related....
    713
    Either the book should tell you or the cover of the fuse box should have a diagram. Try that. I believe the box is in the driver side engine compartment.
    Autostart Autostarter
    Progress Rear Sway Bar
    USDM Bodykit
    USDM Foglights
    1997 AMG C36 (RIP Thank God)
    OEM Bosche Clear Corners
    OEM AdvanteGarde Grill
    Bilstein Sport Shocks
    Eibach Springs
    Zender rear lip spoiler
    W210 mirrors
    Aug 2004
    111
    Thanks.....I got it fixed....
