Results 1 to 14 of 14
Thread: Common part numbers
    Apr 2004
    1,232
    Common part numbers
    Items most people get... add if I missed something
    Covers for door locks (from ML)
    Article number: A 210 766 00 56
    Avant-Garde grill
    Article number:
    B6 688 0127
    A210 888 01 23 [w210] (Requires cutting)
    Chrome framework for automatic transmissions:
    Article number: A 170 267 02 88
    Chrome framework for mechanism vehicles Tiptronic:
    Article Number: 210 810 06 17
    Article number: A 202 267 07 88 7F24
    Tail lamps original Mercedes (ULO)
    Completely knows:
    Article number: B6 680 9891
    Completely red:
    Article number: B6 680 9890
    SLK Sport Pedals for W202
    For Standard Transmissions:
    Accelerator pedal: A 170,300 00 04
    Brake pedal: A 170 290 02 82
    Clutch pedal: A 170 290 00 82
    Foot determination brake pedal:
    A 230 430 00 84 (oval burls)
    A 203 430 00 84 (round burls)
    For Automatic Transmissions:
    Brake pedal: A 170 290 01 82
    White background for heater regulators (of the SLK)
    Article number: A 170 817 25 20
    US turn signal:
    Turn signal left:
    Article number: A 202,826 11 43
    Turn signal right:
    Article number: A 202 826 12 43
    Bulb yellow 5W/21W
    Article number: N 600 000 000 007 (2x)
    Versions C-class W202:
    Article number: A 000 826 9582 (2x)
    Round connector socket: A 003 545 26 26 (2x)
    Connector sockets for versions:
    Article number: A 014 545 8528 (2x)
    Branch link:
    Article number: T4540161 (2x)
    Shelf Instead of Ashtrays:
    Shelf largely: A 202 680 05 91
    Plug socket: A 210 820 09 51
    Tool for removing AI
    W 140 589 02 33
    Parts in 744 silver WITHOUT chrome:
    A 208 760 00 70 9744 - door handle in front
    A 210 760 12 70 9744 - door handle in the back -
    A 208 760 09 77 9744 - end piece in front left with IR and lock
    A 208 760 05 77 9744 - end piece in front right with IR without lock
    A 210 766 03 56 9744 - end piece in the back
    Steel Carter Plate
    Article Number: 202 524 0001
    202 520 0133 Mounting Support
    201 990 0204 Bolt for mounting steel plate & support (6x needed)
    201 990 0991 Mutter for mounting steel plate & support (6x needed)
    202 524 0485 Isolation for steel carter plate (diesels only)
    124 987 0740 Fixation Material Isolation (2x needed)
    201 988 0381 Fixation Material Isolation (4x needed)
    201 988 0481 Fixation Material Isolation (4x needed)
    Stockie Part
    Article Number: 2025241330
    201 990 0536 Screws (4x needed)
    001 994 9845 Lock clips (4X needed)
    Universal 722.6 transmissions Dip Stick
    Article Number: 140 589 15 21 00
    140 991 00 55 (Red locking clip that breaks when you open the cap)
    Assembly & Disassembly Wedge
    Article Number:
    110 589 03 59 00 (Large Wedge)
    115 589 03 59 00 (Medium Wedge)
    900 589 01 67 00 (Small Wedge)
    Rear Emblem
    Article Number: 202 758 03 58 (98+)
    Article Number: 202 758 00 58 (97)
    Spring Pads
    Article Numbers:
    96-99
    Front:
    210 321 01 84 pad#1 5 mm
    210 321 02 84 pad#2 9 mm
    210 321 03 84 pad#3 13 mm
    210 321 04 84 pad#4 17 mm
    210 321 05 84 pad#5 21 mm
    Rear:
    210 325 01 84 pad#1 5 mm
    210 325 02 84 pad#2 9 mm
    210 325 03 84 pad#3 13 mm
    210 325 04 84 pad#4 17 mm
    94-mid 96
    Front:
    201 321 09 84 pad#1 8 mm
    201 321 10 84 pad#2 13 mm
    201 321 11 84 pad#3 18 mm
    210 321 12 84 pad#4 23 mm
    Rear:
    201 325 09 44 pad#1 8 mm
    201 325 10 44 pad#2 13 mm
    201 325 11 44 pad#3 18 mm
    Paint Codes
    Black Clearcoat 040/9040
    White Clearcoat 143/9143
    Black Opal Pearl Clearcoat 189/9189
    Obsidian Black Metallic Clearcoat 197/9197
    Calypso Green Metallic Clearcoat 279/6279
    Aquamarine Metallic Clearcoat 341/5341
    Azure Blue Pearl Metallic Clearcoat 366/5366
    Bordeaux Red Metallic Clearcoat 567/3567
    Magma Red 586/3586
    Desert Silver Metallic Clearcoat 693/1693
    Brilliant Silver Metallic Clearcoat 744/9744
    Tectite Gray Metallic Clearcoat 753/7753
    Aspen Green Metallic Clearcoat 891/6891
    Midnight Blue Clearcoat 904/5904
    W202 CD Changer Cartridge
    Article Number: A 002 820 62 89 (99+)
    Rear Door Sun Shades
    Article Number:
    B6 669 1184 (Left)
    B6 669 1185 (Right)
    Front Nets
    Article Number:
    210 814 00 07 (Net)
    170 814 00 07 (Net)
    220 814 01 01 (Hooks 5x)
    *Use a color code
    Warning Triangle for Trunk
    Article Number: 203 890 01 97
    202 890 00 14 (Mounting Bracket)
    CD Holder
    Article Number: B 67 81 0041
    *might be wrong
    Front Camber Bolt
    Article Number: A 202 330 01 18 C36
    Cross-Over Tube
    Article Number:
    HWA 104 141 01 04 (MY 94)
    HWA 104 141 02 04 (MY 95)
    HWA 104 141 06 04 (MY 96)
    HWA 101 141 07 04 (MY 97)
    Auto Dim Rear View Mirror US Spec Driver (left side) Sun Visor with Home Link
    Article Number:
    210 810 03 10
    CLK Door Lock Pins
    Article Number:
    A 123 766 00 22
    Oil Wrench
    Article Number:
    103 589 02 09 00
    AMG Spark Plug Cover
    Article Number: HWA 10 41 50 0375
    *C36
    SLK Intake Pipe For Mas Relocation
    Article Number: 111 140 21 12
    HOWTO is missing pics
    Updated Mercedes Keys for 98+
    Article Number:
    Remote part# 211 766 36 06
    Blade part #203 766 50 06
    Euro-Spec c43 springs
    Article Number:
    Front : 210 321 22 04
    Rear : 210 324 34 04
    Oem w202 Sunshade
    Article Number:
    Q- 6-67-0001
    Headlight Wiper Kit Addon
    Article Number:
    A 202 820 00 40
    AMG Window Sticker
    Article Number:
    129 584 08 38
    Transmission Pan Magnet
    Article Number:
    A 220 271 00 98
    W204 Flat Badge
    Article Number:
    A 204 817 06 16
    Lenses
    Article Number:
    202 820 57 66 LH HID/Xenon
    202 820 58 66 RH HID/Xenon
    202 820 63 66 LH Halogen
    202 820 64 66 RH Halogen
    170 826 09 90 LH C43 Fog
    170 826 10 90 RH C43 Fog
    Seal, Joint (rubber) for Headlamp Assembly
    Article Number:
    202 826 11 80 LH
    202 826 12 80 RH
    Covering for fogs C43
    Article Number:
    202 698 27 30 LH
    202 698 28 30 RH
    Transmission Cover [includes O-ring]
    Article Number:
    022 997 22 48 (C43)
    140 270 00 91
    Wheel Center Cap
    Article Number:
    201 400 04 25
    ***C43***
    Sep 2005
    680
    Re: Common part numbers
    Originally posted by Ashkan's C280
    Round connector socket: A 003,545 26 26 (2x)
    Article number: A 014,545 8528 (2x)
    Branch link:
    Taking off tool for AI
    W 140,589 02 33
    Hey Ashkan, I was wondering what are all these part numbers? Round connector socket? Connector sockets for versions? Branch link? Taking off tool for AI?
    Thanks.
    Apr 2004
    1,232
    *Updated...because I care. Cheers.
    ~ Ashkan
    ***C43***
    Senior Member Kropf's Avatar
    Sep 2006
    Hudson Valley, NY, US
    126
    Paint Codes
    Imperial Red 3582
    Black 9040
    Silver metallic 9744
    [/B]
    My 1999 C280 Sport is 040 Black
    My 1999 C43 is 197 Obsidian Black
    The 1999 C-Class US Brochure MC-98-902-225 lists the colors as:
    040 Black
    143 Glacier White
    197 Obsidian Black*
    567 Bordeaux Red*
    702 Smoke Silver*
    744 Brilliant Silver*
    891 Aspen Green*
    904 Midnight Blue
    * Metallic Paint
    1999 C43 AMG Black - sold
    - Eagle Eyes: BZ055 Clear Corners with LED 2357A, BZ062 Tails with LEDs; LED lic. lamps
    - VVME H7 4300K HID/Xenon Lower Driving & Low Beams (& replaced Halogen Lenses with OEM Xenon Lenses)
    - Sylvania SilverStar H1 High Beams
    - Silver Star Re-man and improved Trans./Conv.
    - Eibach Pro-Kit & Akebono ProACT Ceramic Pads in Front
    1999 C280 Sport Black - sold
    2005 E55 AMG Black for fun
    2007 GL450 Carneol Red for hauling!
    Apr 2004
    1,232
    hmm I was getting the 9s in front from the dealer, I will update to add yours, but 9040 works... I had called in for it today. Cheers.
    ~ Ashkan
    *Also can this be a sticky?
    ***C43***
    Sep 2006
    126
    hmm I was getting the 9s in front from the dealer...
    A local dealer just explained that Germany has converted the 3 digit codes to 4 digits, but the prefixed 4th digit is not always a '9'.
    My two numbers (040 & 197) are as on the numbers plate on the front radiator supports. And the 1999 brochure only lists the 3 digit numbers. Even my 2005 and 2006 C-Class brochures use the 3 digit codes.
    Member
    Jun 2003
    Orange County, CA
    88
    Go to paintscratch.com and you can see a list of the color codes both in 3-digit and 4-digit. I believe 3-digit codes are typically used for chassis door cards, and 4-digit codes for part numbers/trims/etc.
    Here is what comes up for the MY2000 C-Class.
    Magma Red 586/3586
    I know if you try some different google terms there are some sites that have more detailed info.
    2000 C230 Kompressor Sport
    Apr 2004
    1,232
    Does anyone have the part number for the e63 dead pedal?
    ***C43***
    Sep 2006
    126
    Headlight Lenses
    Seal, Joint (rubber) above Headlamp Assembly
    202 826 11 80 LH
    202 826 12 80 RH
    C43 Fog Light Lens
    170 826 09 90 LH
    170 826 10 90 RH
    Covering, Wheelhouse - Plastic shields below/behind fog lights and in front of front tires (C43)
    202 698 27 30 LH
    202 698 28 30 RH
    Cover,Trans - Transmission filler tube Cap includes O-ring 022 997 22 48 (C43)
    140 270 00 91
    Wheel Center Cap
    201 400 04 25
    Member
    Jun 2003
    Orange County, CA
    88
    W204 Flat Badge (direct replacement)
    A204 817 06 16
    OEM W210 Avantgarde Grille
    A210 888 01 23
    Apr 2004
    1,232
    the w210 grill is not a direct replacement for the 202 it must be cut. I included the part number for the grill that will fit the w202 towards the top of the list. Cheers.
    ~ Ashkan
    ***C43***
    Member
    Jun 2003
    Orange County, CA
    88
    And I included the W210 PN because it's something like $300 cheaper from the dealer. Probably even less from a wrecker.
    I think it's worth to note it takes less than an hour to cut it down (less than 30 minutes really with the right tools). In case anybody wanted an DIY OEM replacement.
    Jun 2007
    490
    Is the w204 flat badge bigger than the original w202 flat badge?
    Ive seen it on a w204 and it looks big.
    4,533
    Coin tray (fits below HVAC, where cassette/phone pad resides): 202 683 00 91
