Results 1 to 5 of 5
Thread: Wut Size Tires Should I Run
    Question Wut Size Tires Should I Run
    HI I WANT TO KNOW WHAT SIZE TIRES I SHOULD RUN ON MY STOCK MONOBLOCKS IN THE REAR(8.5).I PUT 245-45 AND RUBS EVER TIME I SHIFT.I WAS THINKING ABOUT PUTTING THE STOCK SIZE BACK ON (245-40),BUT I NEED TO GET TIRES NOW CUZ I HAVE A NAIL IN THE LEFT REAR AND LEAKING AIR.I PUT A HOLD ON SOME BRIDGESTONES TODAY AND MIGHT BUY THEM TOMORROW.SHOULD I GET THE 245-40.I KNOW THE 245-45'S RUB BUT COULD I RUN 245-50'S?:beard:
    For this round I suggest you stick with the stock tire size (225/45/17 front, and 225/40/17 rear)
    Then as a next step, I suggest that you visit
    http://www.tirerack.com/tires/tirete...nersmanual.jsp
    and start reading as much as you can, To begin with you might want to check out the sections labeled "The Plus Concept" and "calculating tire dimensions"
    I think you'll find that site quite useful and it would be worth while to get a better understanding of the most important part of your car.
    Also, it's not necessary to type in all capitals, as it's considered screaming. And as a final note, you may want to cut your signature down a bit, as it takes up quite a bit of screen space, and hinders people's ability to read threads.
    Also keep in mind of different tire brand for the given size (for example 225/40/18) some has narrower cross sectional width and some has wider.
    What this means, it affect the clearance between the tire sidewall and fender.
    Jan 2005
    564
    if the tire is still good... get the tire repaired....
    I have a brand new nitto NT450 with a nail I still need to get it patched up.. it would be a waste to throw away perfectly good tires
    Good point...but in this case, he's running an incorrect higher aspect front tire in the rear--something that should be corrected.
