john, all of these things are totally normal for benzes. the reason your car works better when cold is because the coolant and air intake temps are cool and the ecu advances the timing until the engine warms up, then it retards it slightly to prevent detonation. the trans viscosity is more or less the same for all vehicles, only some ATF's are GL-4 certified(GL-4 is a medium viscosity gear oil certificate). if you want a good performance ATF, contact www.redlineoil.com and ask them which of their ATF's is suitable in your car. if you have a pre 96 benz, you can use their Synthetic AFT, if you car is post 96, then you will most likely be able to use their D4 ATF(which is GL-4 certified btw). this is what im running in my 740i, and I love it, the differenc in responce is quite noticable, and the tranny runs much more cooler=longer life, better performance.Originally posted by mr. gatsbury
I don't believe this has ever been discussed but and I am not mecanically inclined by far. When I first start my car (mind you that I am on the East coast) it is much more responsive and has way more torque than when it is warmed up. So the question is: Is the cold engine what makes it more responsive? If so I guess there is nothing I can do. Does anyone notice that when you first drive your car for the day and the trans fluid is at it's thickest, when you let your foot off the gas it actually pulls the car almost to a stop at low speeds (I have an auto). It also is way responsive at this time as well. I can play with the pedal and get tight response, almost similar to playing in a low gear with a manual trans. So I was wodering if anyone has thought of using a trans fluid with a thicker viscosity at higher temperatures or would I damage something?
nenad
ps try redline's motor oil as well, its tha shiet!
