I believe there is actually a harness under the carpet that you can tap off for this. But since I dont know exactly where it is I will tell you how I did it on a 124. Should be almost if not the same.
Pop the 2 door pins out. The lower one contains the power, I forget which one you will have to experiment with a meter, the top is the on off switch (for the on off switch dont use the ground (brown) use the other wire.
Thats how I ended up doing it on a 124 as he wanted underdash neons so I hooked up just like you would door sills.
Hope that helps some.
