c36 steering wheel
Just got my 95 c36. Does the wheel have tilt somewhere and I'm just not seeing it?
Already searched....
from what i'm aware, the steering wheels on w202 does not have a tilt option, only a telescoping option that lets the steering wheel go in and out. not up and down. If there is nothing directly under the steering wheel, then you don't have it. You definetely can't miss it.
thanks....thats what I figured. Also, I have the same squeeking when turning that slammed_C had. I looked at his thread about it but there are no replies. Anyone know what this is or how to fix it?
same with mine
i have a 95 c220 and my steering wheel is making a squeeking sound to.
I have no idea what creates that squeeking. I also get it only when i do full u turns and it doesn't make the noise all the time either when doing that, so i don't know sorry...does it make noise even on soft turns?
when it happens
mine hasnt happen for a while. but it usually happens too when i make a sharp turn or something.. or a quick turn.. but when turning it softly it didnt.. it so far has been making noise when its cold.. and now that it is not cold there is no noise
This sounds like a fairly common problem. We definitely need to figure this out soon. I'll probably end up taking the thing apart soon. I'll let yall know if I figure it out.
Mines pretty much gone now. Found telescoping switch thanks.
