What length lines do I need to replce the stock rubber brakelines with SS lines. No one seems to have kits, just different lengths.
Thanks,
~dnm
You can buy the stock rubber hoses and then measure the length to give you an idea. Then return the lines and order teh ss ones. If you did do this method, be sure to make the ss lines a few inches longer (rubber lines can stretch).
Or you can wait ill another member chimes in and says the lengths.
DLS
kodiak
Try to call troutman..
They should have the spec for your car..
I got mine from them...
http://germanpartsusa.com/sbb.html
J Irwan
