Results 1 to 12 of 12
Thread: Howto write-up: Steering wheel removal
    In Charge martattack's Avatar
    Jan 2004
    Kirkland, WA
    816
    Howto write-up: Steering wheel removal and Instrument Cluster Removal
    I've added a write-up to my website about how to remove the steering wheel. It is actually a prequel to removing the instrument cluster, so look for that soon.
    EDIT: Instrument Cluster removal has been added. Find that here:
    http://202tech.mkosonen.com/howto/instrument.html
    The actual write up is at http://202tech.mkosonen.com/howto/steering.html
    The rest of my site along with other how-tos are at http://202tech.mkosonen.com
    Look for more coming soon, especially since I'm out of school now with lots of free time (until I find a job).
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    1,169
    thanks man, i love your site lots of good info
    Thank yuo man for time and very good info!
    Rene
    \'00 C280
    \'99 ML320
    639
    thanks Friend.
    A "how to section" in this great forum should be usefull to file all this information
    253
    i agree...
    Sean
    Thanks as well. I have your link saved on my favorites since I will be doing all this soon.
    Moderator Sulaco's Avatar
    USA
    1,306
    While following this very helpful write-up in order to get my instrument cluster out (in order to clean it and adjust my fuel gauge) I ran into one huge snag.
    The 2 screws holding the air-bag cover are deffinitely not T25 Torx heads. The T25 torx head was far too large for these holes. I used a flashlight and a mirror to look at them and best I can tell, they look like the screwdriver that turns them has a tip that's pentagonal and tiny. I tried every size below T25 Torx that I have and still didn't find anything that would fit. My car is a 1994, and I guess that's one difference between my older car and your newer one. Also, removal of that godforsaken knee-bruising panel didn't require so many screws/bolts to be removed on mine. It's not that the screws/bolts were missing, it's that they were never there.
    If ANYONE has ANY idea what the hell turns these mysterious airbag-cover screws, I would be GREATLY appreciative and would offer cyber-sexual favors in exchange, if such a thing exists. Maybe I should stop talking now.
    CURRENT:
    You're right, the airbag mounting bolts aren't a T25 Torx, they are a T30 Torx and there is a special tool from MB that is a little longer than most Torx sockets. Every airbag in a Mercedes since 1986 has been held on with 2 T30 Torx bolts.
    Jan 2004
    Kirkland, WA
    816
    I had a feeling they might have been T30, however I didn't have a T30 torx laying around. T25 worked just fine for me. However, I don't think is going to help our friend Sulaco because he thinks T25 is too big, let alone T30. I will change the website to say T30 instead.
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    USA
    1,306
    Wow, thanks for the heads up on the Torx 30. I don't know WHY in the hell that looked so small and strange to me using the mirror/flashlight combo, but I had it wrong. Got the cover off and following Boominbenz's instructions very closely and carefully at this stage. I've had sticky gauges and a mis-reading fuel gauge for more than a year now, and I pray this will alleviate all that.
    Thanks tremendously, guys.
    CURRENT:
    Jan 2004
    Kirkland, WA
    816
    No problem. The Torx heads do always seem like they are too big for the screw, so I usually go one size up from what I think it looks like.
    Good luck with the rest of it!
    Martin
    2012 535i
    2005 545i - Retired
    1994 C280 - Retired
    Great Job!!
    Martin
    Great job on your site. I just wanted to commend you on your
    effort to provide a how to on W202
    I was going to start something like that but, I dont know jacked squat..
    thank you again, Its now on my favorites
