Results 1 to 8 of 8
Thread: Seat Alignment.....
    Seat Alignment.....
    Anyone know if the 2 front seats need to be align properly?
    What I meant is do you need all the bolts that are attached to the seats like the back rest need certain tightness?
    Plus for the knee part that goes up and down, do you also need to tork them to a certain tightness also?
    Yep its called make sure they dont come off tight
    You mean to say I got to count how many turns I did on each bolt to make sure each bolt will have the same tightness?
    Just make it tight is all im saying. last thing you want is for your seat to go flying.
    I don't have any problem on the 4 corners floor bolt. But I think my problem is the one your butt is sitting on. Seem like the back part is not raising high enough to level with yours knees. And those 2 foams underneath seem like it's getting stuck when you try moving it backward or forward.
    this isnt the one that had the damage motor that you are replacing right?
    No, this is the one I showed you. I took out the seat and installed the new lower frame. But everytime I try to adjust the height or try to level it feels like something is slipping and won't hold the adjustment. And for the up and down part of the knee I can see the seat would only go up and down on each corner w/c is the front right and the left rear. I'm guessing that I do need to balanced out the bolts on each side when tightening them.
    i'll have to see it first hand. but from what is described looks like an adjustment just as you said.
