Results 1 to 5 of 5
Thread: Spak Plug replacement and wire replacement.
    Hey there i just got a c230 K and wanted to change teh plugs and wires on it if i were to get 8mm plug wires would that cause any problems also what type of plugs should i get as well as wires
    Thanks fo all the help
    Apr 2003
    435
    For plugs use only what the book calls for:
    Bosch F 7 KTCR.
    You can get them at the dealer fairly cheap.
    I would stick with OEM ( original ) wires.
    2000 C 230 K
    Mar 2005
    1,069
    do 230k's have plug wires
    sometimes
    06 C55 AMG
    09 Murano SL
    Mar 2005
    1,069
    I said that cos i thought they used coil packs straight above the sparkplug
