Results 1 to 9 of 9
Thread: Ordering help....
    Ordering help....
    K, so I am going to be ordering the following
    Bilstein sprt shocks (taken care of)
    magnecor 8.5mm spark plug wires (need help on where to get them from , possibly good deal)
    brake pads ( would like to lower dust output, best place to order all four pads)
    spark plugs (which ones to go with, and best place to get/order them)
    Ball joints (best place to order them)
    Bushings ( best ones/place to order)
    Want to do all asap so quick response would be awesome! thanks guys in advance =)
    99 c280 (WHITE)
    In the midst of modding.
    Mar 2004
    447
    if you want some poly bushings there is a seller on ebay that sells them for $50. Also get the ball joints from ebay for about $30
    i saw those poly ones, how many would i need total to replace all of them and are they just as good if not better? i also found the ball joints on ebay . thanks!!! (still need help on the other stuff tho) thanks!
    99 c280 (WHITE)
    4,533
    contact Linda @ Apex Performance for wires: www.apexperformance.net
    where is apex performance? you have a number possibly? thanks a ton!
    99 c280 (WHITE)
    Mar 2004
    447
    u'll just need 2 poly bushings (one for each side) They're better because they are solid, but would make the ride a little bit stiffer.
    Apr 2004
    1,232
    I like ngk plugs their ird plugs are the ones used in brabus cars, so I would go with them
    ***C43***
    4,533
    I use ngk plugs. Nothing special.
    1,719
    Re: Ordering help....
    magnecor 8.5mm spark plug wires (Cklasse, B&M muffler)
    brake pads (i prefer portifields for the fronts, buts they'll warp the stock rotors if you brake alot/hard like me, so i just change the rotors when they are warped, i'd get OEM for the rears since they don't get dusty)
    spark plugs (Stock, really don't make that much of a difference, I've tried $10 ones and stock $2 ones, feels all the same)
    Ball joints (Dealer if you have wholesale account, otherwise mercedesshop.com)
    Bushings (I used the poly ones off ebay, you'll hear cracks and squeaks but well worth the handling capabilities,100 for the set)
    Got BRABUS?
