yes, same car, i have em.
did you check to see if the bulb is burnt out, these also work as fog lights, when you have your main beams on pull the headlight switch out; toward you, there are 3 positions it can be in and if you pull it out into the 2nd or 3rd your fogs will come on with either your parking or main beam lights. if not they are burnt
