Results 1 to 25 of 30
Thread: throttel responce
    Dec 2004
    382
    throttel responce
    is there any way to improve the throttle responce, for example it feels real slow off the line and huge pedal movments result in not very much rpm movement
    Nov 2004
    1,757
    any power add-on part will help out. intake, exhaust, chip, higher atomization fuel injectors...
    nenad
    2002 S500
    2002 CLK430 w/ 5.5L swap
    2002 SLK32 AMG
    2003 S430 w/ 5.0L swap
    2000 ML55 AMG
    Dec 2004
    382
    what about computer tuning i was told all cars are tuned to 75% of what they can do for the general public to used. i am interested in the fuel injectors can you explain more and sugesst where a good place to start would be ? what i can expect to gain how much it might cost ?
    1,719
    check the basics, Airfilter, spark plugs, etc. Change you diff fliud, tranny fliud, if you haven't already. Every little bit helps out a bit.
    Got BRABUS?
    hey, what kinda benz u got? 280, 230, 220, 230K, 36, 43???
    if u press the accelerator a bit, does the engine rev up or do u gotta press it alot for the engine to start revving up?
    on my c220, i had to press the gas all the way to the floor before it'd pick up, this was because the throttle cable was loose, u can hand tighten it your self on the throttle body, just follow the cable to the end, u see a plastic screw.
    check your fuel filter, plugs etc like 714guy said.
    95 C220 Moonstone/Gray mb-tex
    MODS
    - Replica Avantgarde Grill
    - Flat hood Emblem
    - Plat +4 plugs
    - XM Radio
    - pioneer 12\" DVC Sub
    - Boss amp
    - H&R Springs
    - Bilstein sports up front
    - 17\" MOMO\'s
    Nov 2004
    1,757
    as for chip tuning, I dont think cars are detuned 25%, that means that a chip upgrade would yield about 50 hp on a c280. most cars are detuned about 5%, just to compesate for different fuel qality around the world.
    as for the injectors, slightly higher flow rate and higher fuel atomization might yield better throttle response as well as slightly increased HP.
    great place to figure out the injectors you need would be www.rceng.com go to the technical data section, and enter all the info and you will get the required flow rate. as for the brand, I would highly recommend accel, which is what I used on my C280.
    but, as others said(and I forgot to mention), make sure your car is in tune, if you havent done a complete tuneup in a while, that would be a good start.
    nenad
    2002 S500
    2002 SLK32 AMG
    2000 ML55 AMG
    Jan 2005
    564
    this is why I think the vdub 1.8t motor is such a bad ass daily driver ... its throttle is so touchy.. 1\8th of an inch on the gas and you go from 70-80mph in a few seconds! no joke!!
    I think this is why maybe Mercedes went with a 1.8 supercharged motor from 2.3 liters.. 1.8 liters rev higher =)
    Dec 2004
    382
    i just did my air filter, 0w40 mobile one, it has platnium 4+ spark plugs, i removed the restrictors in my mass air, it sounds like i have a turbo now, as far as a tune up thats what my mechanic said air filter plugs thats it is this true ?
    how can you tell if there is something wrong with the fly by wire throttle control ?
    Mar 2004
    447
    haha. I think thats funny If I was going 70 and I stepped on the gas for a few seconds I'd be doing over 100, but then again I don't have a c230
    C55 Charter Member
    Jun 2005
    1,116
    Re: throttel responce
    I =know= some people are going to jump on me ... but search for RON93 [i.e. setting the car to expect US Octane 91 or higher fuel] and read posts from me c55m8o and my previous identity 98c43amg (not only here but on other MB boards as well) . It's like a different car ; but as speedybenz was able to quantify with his analysis of timing advance/retard with it on or off (set to default), it does have drawbacks and safety issues to the engine if you run in areas of the country that reach extremely hot temperatures.
    C55 Charter Member
    Jun 2005
    1,116
    ...and turn off the A/C (or hit the 'EC' button to keep the fan on but turn the compressor off)...
    Dec 2004
    382
    when i a performance driving i turn the A/C right off and only crack the window alittle for less wind resistance, the mobile one made a difference i will explore the ron93 setting
    i live in canada so there will be no need for extream heat
    Apr 2004
    1,232
    how do you remove the restrictive part of the mas, that mesh platic part?
    ***C43***
    Dec 2004
    382
    yes
    Apr 2004
    1,232
    well how do you get it off?
    ***C43***
    First you need the security torx bit to remove the sensor. Then just hit it out.
    Nov 2004
    1,757
    you remove the safety clip around it and take off the screen. I've done it, no difference, though.
    nenad
    2002 S500
    2002 SLK32 AMG
    2000 ML55 AMG
    Apr 2004
    1,232
    no difference at all?
    ***C43***
    Dec 2004
    382
    carefully it will break so you cant put it back on
    Nov 2004
    1,757
    nothing significant.
    nenad
    2002 S500
    2002 SLK32 AMG
    2000 ML55 AMG
    Dec 2004
    382
    sound difference produces deeper exhaust note and turbo like sound when you full throttle it
    Apr 2004
    1,232
    well performance wise any changes?
    ***C43***
    Dec 2004
    382
    minimal probally not noticable everything helps
    Apr 2004
    1,232
    well I tried taking it off and I ended up breaking it... I got it all out and the metal mesh thing after it, I used a flat head screw driver to remove the ring, not too much of a sound change imo but I guess I need more time driving it, hopefully I didn't fuck anything up
    ***C43***
    Apr 2004
    1,232
    does this turn on a check engine light? I really hope I didn't ruin my mass cause my check engine light just came on after I did this, like 20 miles after.... DAMNIT
    ***C43***
