Results 1 to 4 of 4
Thread: Can Someone Help?
    Can Someone Help?
    Anyone know how to remove the cover piece to the center pillar between the front and back doors (like where the seatbelt is) on the interior? thanks!
    99 c280 (WHITE)
    In the midst of modding.
    asap if anyone has this info... thanks! =)
    99 c280 (WHITE)
    171
    In my 1995 c280 there is a plastic cover at the base of each pillar.
    pull up and out, near the bottom and at the corners, to remove. (there are no screws, just clips)
    NOTE. You must loosen the front and back sills first ( pull up at corners near pillar), since the cover sits beneath them.
    after that I believe the rest can be removed easily.
    1,069
    yea what that guy said.
    there is plastic clips under the door surround thing (the big rubber strip thing which goes the whole way around the door opening. on both the front and rear doors
