Results 1 to 3 of 3
Thread: WTD: heavy-duty clutch & pressure plate for C36 engine 5-speed conversion
    Does anyone have a source for an aftermarket/heavy-duty W124 clutch ?
    I'm mating up a 5-speed from a 1986 W124 300E, and would like to use a stronger clutch (perhaps a 4 or 6-puck clutch) and a heavy duty pressure-plate to handle the HP and torque from a AMG M104 C36 engine.
    Does anyone know if the clutch and pressure-plate from a 5-speed M104 C280 or C36 will work with a 1986 W124 tranny ? They are the same family of trannys . . .
    TIA,
    :-) neil
    Apr 2005
    380
    I cant help much but you can try clutch masters and see what they can make. I was always thinking about the 6spd from the 2002 c230. Let me know how this goes for you I would love to know.
    1993 ZX6E
    1996 C36
    1972 240Z
    1993 Bayliner 1750
    The one who dies with the most toys wins!
    1,069
    hopefully the tranny will handle the beating of a h/d clutch. wen i upgrade myne i will prolly use a semi ceramic/kevlar sided clutch to allow slight slip to not break anything, as you may do with a on/off 4-6 puck
    -Logan-
