Page 4 of 4 FirstFirst ... 234
Results 76 to 93 of 93
Thread: W202 Euro Projector Headlights
  1. #76
    Originally posted by stox
    Outside of toasting the headlight wiring harness, flames bursting out from under your hood, and the ECU going wonky, no side effects to speak of.
    Sorry mate, my English is not so good. Do you mean, there will be no bad side effect at all?
    What do u mean by ECU going wonky? Will the ECU damage?
  2. #77
    May 2003
    4,927
    Do not use higher wattage bulbs it will burn wiring!
  3. #78
    Will it only burn wiring? Will it damage the ECU?
    I have ECU problem right after 1 week using 110W bulb...really sad...I dont know whether it is just coincidence...
  4. #79
    May 2003
    4,927
    I guess the ECU could go crazy...perhaps you fried your ECU
  5. #80
    arrgggh..stupid me...i fried my ECU?
    so higher wattage bulb will burn wiring..how long is it gonna take to burn wiring? immediately or take some time?
  6. #81
    Feb 2006
    199
    just get hids.... less power consumption and waay more light. i used to have 110w bulbs too but they shorted out my wires somewhere and it was a hefty repair bill. BUT NOW i got 35w hids
    btw do the projector headlamps actaully project the light like its suppose to or is it just for looks?
  7. #82
    Sep 2004
    525
    Sorry for the sarcasm. Two things will probably happen, you'll burn wiring, connectors and relays, and the voltage will be too low to your ECU, among other things. Your electrical system is not engineered for such high wattage bulbs. Chances are your ECU will clear up once you put the regular bulbs back in. If you're lucky, you haven't burnt the wiring yet. Put the 55W bulbs back in NOW before too much damage is caused.
  8. #83
    Thanks for your advices..my bad...I used 110W bulbs....
  9. #84
    so question on the projector headlights... mainly for anyone that has them, would a set of "angel eyes" be able to fit to the surround of the projector???
    i think that would look pretty sick....
    99 c280 (WHITE)
    In the midst of modding.
  10. #85
    99 c280 (WHITE)
  11. #86
    Apr 2003
    1,290
    IM not that sure because ones you open the light in the back you have no accesses going to the front. I thought about this and IM like they would look good!
  12. #87
    no offence..angel eyes are made for BMW..not benz...i love projector lights..just wish they had dual projector lights at a good price but angel eyes is just too much...
  13. #88
    well like the stock ones the glass lens in the front is removable to gain access... is this not trure on these ones??
    99 c280 (WHITE)
  14. #89
    May 2003
    1,669
    the angel eyes for the e36 look a bit too small. they DO sell the CCFL light tubes for other cars like the is300 and so on that might fit.
  15. #90
    Apr 2003
    1,290
    these dont come apart
  16. #91
    Toronto, Canada
    2,244
    I finally got my projector headlight today!!.. YEAH.. pics soon.
    hey Jstrat85... how did you modify the projector side to fit xenon kit?
  17. #92
    Apr 2003
    1,290
    i drilled 2 hole on the bottom and one hole on the cap that you can reomve to get acceses to the bulbs and i ran my wires from there and spliced into the oem wires. and wala!
  18. #93
    Toronto, Canada
    2,244
    what type of bulb did you use?. did you have to modify where the bulb sits?
