I am not sure if this belong to performance or repair. Bounce this around if needed.
I tried to restore my injectors back to OEM specs without spending too much nor ship them off to Cali (shipping+turn around time at 3 days plus two overnight shipping cost).
I know profesional cleanup will require ultrasonic bath and bench test on the spray pattern angle and flow rate. The last two is something the pro has to do, but I figure if I could do the cleaning myself - why not.
For the ultrasonic shaker, I borrow a medical ultrasonic shaker/waver from a friend who works at medical lab. Dont ask what I had to do to convince him -- it's almost pathetic
Then I bought a BG 44K -Fuel Cleaner and Injectors and BG Fuel Injector Cleaner for "Pro & Tool."
I mixed them in a stainless pan, then dip the whole fuel rail. Moreover, I took the rubber seals/rings off the injectors and dip the injectors in the very same pan -- I tried to leave the plastic outlets dry.
Then...shake ...shake...shake.. for 15 minutes!
Fiola!
Today, I went to Hav Machine Shop and have them test the injectors... Here are the result...
Inj - Leak Test - Spray Pattern - Failure no. 0-8 FlowRate(ml)
no 1 pass Good 56 ml
no 2 pass Good 57 ml
no 3 pass Good 56 ml
no 4 pass Good 57 ml
Total cost is $29 in BG products.... and very satisfying outcome!
The only set back is... the Injectors' black paint is gone
