I have a replacement set of LCA bushings. Though it's only for one arm.
i have those poly bushings and they work fine. You only replace the bigger one though, which is the one that tends to bust the most.
Originally posted by omeyhomey
is it the same for the W140 as well? they look identical, i just can't tell exactly.
Im confused which one normally gets busted the front front control arm bushings or the rear bushing in the front control arm (b/c there are two)?
I am not sure if the W202 is the same as the W140, but for my W202 the rear front LCA bushing is the one i changed, its the bigger one of the two.
