1- Roll ur window down all the way
2- and look in-between the window and the door card(interior
panel), you should be able to see a black rubber peice(weather strip)
pushinging against teh inner window...
3- Pull that son of bioch weatehr strip out,
4- get ur razor out
5- slice across the top of the weatehr strip off by 20-40%
6-get ur window tint
7-put that weatehr strip back in after the tint is done.
8- the negtive of cutting the weatehr strip will increase the cabine noise.
How to remove teh weather strip???
steps:
1- remove the door pin
2- gentally pull loos the upper portion of teh interior panle(door \
card)
3-make sure the panel is lose enough
4- use ur fingers(if u have stronge hand) or else use plyer to pull
it out(easest.)
questions plz call me at 510-697-2777 at anytime 24/7 i normally don't sleep much
