you mean the combo relay, the big black one in the fuse box?
nenad
Looks like my combination switch is on its way out. Before I dive in, does anyone have any tips or pointers for its replacement?
nenad
2002 S500
2002 CLK430 w/ 5.5L swap
2002 SLK32 AMG
2003 S430 w/ 5.0L swap
2000 ML55 AMG
Sorry, I meant the combination wiper/turn signal/washer/passing beam switch. At least that is what I was going to look at first.
The symptom I am trying to diagnose is that the wiper has been "stickng" in intermittent mode every once in a while, lately. I can set the wiper to slow and fast, from intermittent, but I can't turn it off. A few cycles to slow or fast seems to fix the problem.
My first guess was to take a look at the switch, and its contacts if possible
2002 S500
2002 SLK32 AMG
2000 ML55 AMG
Sounds like it could more likely be the combination relay. That actually controls the intermittent wiper. It's a tough call because the combination relay and combination switch control nearly the same things that are known to go wrong.
2012 535i
2005 545i - Retired
1994 C280 - Retired
Thanks for the suggestion. I think I'll try the relay first. The relay should be easier to change, costs half as much, and at 100K miles, is likely to go bad soon anyway. It's located under the fuse panel, right?Originally posted by BoominBenz
Yes, it is.
2012 535i
2005 545i - Retired
1994 C280 - Retired
Where can the relay be purchased? I haven't been able to find it anywhere. My blinkers nor my wiper work so I am assuming it is the relay. Let me know! Thanks!
1998 Mercedes-Benz C230
.:Calypso Green Metallic
.:HP Evo 18s on Pirelli P-Zero 235/40/18 front & 255/35/18 rear
.:Avantgarde Grill
.:Titanium Tint 16% all around/ Quantum Tint Full Front window 35%
.:Lowered with H&R Springs & Bilstein Sport Shocks
I bought mine from the Benz Bin, www.thebenzbin.com. It was around $80.
Thanks for the link! I don't see a combination relay..only the switch. Which did you get? It fixed your problems?
.:Avantgarde Grill
Look under engine electrical, and then relay. There you will find a list of relays for your car.
I only found these relays under body electrical.
http://mercedes.thebenzbin.com/?year...Field22222.y=3 There doesn't seem to be one im looking for.
.:Avantgarde Grill
Sorry about that, it was under body electrical. As for the relay you need, I don't know, as I have a '96 C36, and obviously, the '99 230 is different. Hopefully, another member can point you in the right direction.
my wiper switch seems a bit funny too, i used to put it on setting 1 and it would wipe one time and then stop.. i thought hmmm.. setting 2 is like lightning fast and setting 3 even faster!!Originally posted by stox
but now setting 1 is also FAST and continious! lol
Standard 1999 C230K Sport
Mileage: 120K
Tyres: Pirelli P6000
