Results 1 to 9 of 9
Thread: installed led strips
    Jan 2012
    8
    contemplating if i should keep it or not.
    Senior Member jc1kz's Avatar
    Aug 2012
    TX
    225
    NOT... it would be too bright at night unless you have a way to dim them or turn them off...(just my two cents)
    Feb 2011
    Fremont, CA
    1,900
    if it was under the footwells maybe br that location itll just distract you.
    Jan 2012
    8
    Surprisingly it does not blind me or distract me at all. However I might consider moving it around and try other spots like the footwells.
    Apr 2011
    Antarctica
    551
    Quote Originally Posted by hello1234 View Post
    It took me 12" strips to illuminate the footwells to a point where the brightness is bright and noticeable.
    Jul 2013
    12
    I agree with the group. Foot-wells are the place for the strips. Classy, yet not cheap looking.
    Sep 2014
    9
    Thinking of the leds in the footwell. Is there a build thread for thism?
    Cheers.
    Aug 2014
    1
    We have the same interior! The same cannot be said for our taste in modifications though... Yuck.
    May 2015
    Haddiscoe, Norfolk, GB
    8
    I have blue LEDs under the back doors run from the courtesy lights, holograms under the front doors, white LEDs under the bonnet to see what I'm doing and I'm trying to fit an illuminated triangle in amber and red flashing LEDS as worning lights the last set of LEDs are top of the rear window just to the curve as high level brake light I have been thinking about rope LEDs running under the foot well around the sides into the back then along the under side of the back seats.
