Does the bac look like it sits way lower than the front?Originally posted by Rocky
Yes it handle better.
Using #3 up front and #2 in the back i believe. The front is tucked a little, the rear is tucked a little more then the front.
But remember this..each car lowers differently no matter if you use the same spring pad combo. That's the whole reason why MB uses spring pads because each car will sit differently even from factory.
