Originally posted by jnolte
1998 C43
K&N filters
Harmonic balancer
new belt x2
new idler pullly
resealed some oil leaks
tranny fluid. filter x2
front flex disc
cabin filter
fuel filter
c32 brakes
oil changes mobil 1 0w40
water pump
coolant flush change
re greased wiper arm
tires x4
Needs new engine mounts,tranny mount, front LCA bushings, rear brakes
Add to my list
New EIS and key
Resealed Oil pan
Reseal DIff
New Diff cover
Drilled SL rear rotors
New rear brake pads
new Diff oil
rear flex disc
Still needs Engine mounts, LCA bushings and Tie rod
